I have uninstalled Devon Think but still getting link of this when I Control click on some items though I have uninstalled and re-installed that twice.
(I didn’t grab screen shot nor note because I know that).
During uninstallation, instructions from their website were followed using APPZapper and AppCleaner but still I am getting the Devon Think link.
Is there any suggestion about this?
Hello Leigh,
You may be getting that link because there could still be some Devon Think files that are still on your computer, and therefore you will have to make sure that all of them have been successfully removed.
If you uninstalled Devon Think from the control panel, you will need to do the following:
On your computer go to C:Program files and see if you can find a Devon Think folder.
In it is there, you will need to delete it will all the files in it, completely.
After that you will need to run CCleaner to remove any associated files that could still on your computer. If you do not have CCleaner on your computer you will need to install it.
Carl
