anonymous
7060 points
Posted on - 09/01/2012
Hello expert,
I have utilized Ubuntu 11.04, but I think it work up in all Linux distribution.
However, I get this error.
Please help me to solve it.
Thanks a lot.
Citrix Receiver
SSL error
Contact your help desk with the following information:
You have not chosen to trust "/C=US/ST=/L=/O=The Go Daddy
Group, Inc./OU=Go Daddy Class 2 Certification Authority/CN=",
the issuer of the server's security certificate (SSL error 61).
        Quit
To resolve the issue that you are getting, you will need to use the following steps:
You will need to log on to your PC, and then locate the Citrix installation folder.
It could most likely be here: /Applications/Citrix ICA Client.
You will need to create the following folders: /keystore/cacerts
After that you will need to go to a Windows based computer, and then in Internet Explorer, you will go to Tools >> Internet Options >> Content >> Certificates >> Intermediate Certification Authorities(TAB)
You will need to find the name of the cert in the error message above and then click to highlight it.
After that click Export >> Next >>and then choose DER encoded Binary X.509 (.CER) >> Next
You will then click Browse >> and then select a location >> Make sure that the file name is the same as in the error message.
And then you will go to the file on the desktop and rename the .cer extension to .crt.
After that get that file to your Ubuntu PC, and then copy that file to /Applications/Citrix ICA Client/keystore/cacerts.
Try again.
Carl
