I haven’t get the data from PDF complete uninstall.
Hello everybody,
I haven’t get the data from pdf complete uninstall. I have to completely delete or uninstall all the pdf format files that was corrupted from my computer system. I am using windows 7 starter and was afraid that those viruses may spread in the computer registry. How can I get rid of those files?
I really need your help about this matter.
Thanks and have a nice day.
Best Answer by Thornton Patricia
Answered By 0 points N/A #175067
After uninstalling pdf complete delete all files stated below by manually finding them in os installed drive and careful when reinstalling software use original cd or standard version while downloading from websites and try to delete those files from registry entries in windows system 32 or 64 folders then restart computer otherwise use avast antivirus and choose boot scan sure you problem solved without any spread.
Hope these shall helps you
Thanks
Answered By 0 points N/A #175068
You want to uninstall the PDF complete from your PC. You can do that by clicking on the uninstall tab in the “add or remove a program”. If that doesn't work to your satisfaction, you can use a registry cleaning software such as Ccleaner. You can also use an antivirus in this regard.
