I want to install adobe flash player and log in as a guest for the website just to allow the downloading process. I just want to clarify if the installation is valid even though you log in as a guest?
I install adobe flash player as guest is this verified?
Administrator can control the application installation of the other account. If administrator set permission to install the application for guest account you can install the application. But as long as you are logging as guest, your installation valid for only for the guest account unless administrator change it. If administrator deletes the guest’s user directory every change will revert.Â
Hello Charles Bowers
You never need to sign up to download and install Adobe Flash Player. You just need to visit the Adobe Flash Player official site to download it and install, but while you are installing it you need to close all of your browsers. Go here to download it. http://www.adobe.com/support/flashplayer/debug_downloads.html
Thanks for using Techyv
Best of luck,
Maxwell Mark
