I just purchase a laptop, but i cannot play farmville ?
I just purchase a laptop, but i cannot play farmville ? its just stops loading halfway, what to do ?
May I know what’s the browser you are using right now? Because the problem may not be the laptop but the browser itself,It’s possible that the flash player installed with it is not the latest one or the windows you have is window 7.The best way you can do is try to uninstall the flash player you had now and then install the latest version,just download the Adobe flash player beta version and active x beta, to make this more effective there is also this debugging program that should go with it. It’s because farmville is compatible with beta and therefore only works with it.
The problem you are having has really nothing to do with your computer since it’s brand new but I guess it’s with the program installed. If you can’t play Farmville on your computer then there is probably something lacking in your system that you need to install or may be updated.
Farmville is not your ordinary computer game that needs to be installed on your computer to be able to play it. It is a kind of online game that is played within a web browser and uses the flash player program for its graphical processes.
Upon loading of the game in your web browser, it already uses the flash player installed on your computer and this component helps the game to easily finish the loading. If there is a problem in your flash player or this program is somewhat outdated then most likely that you will have a problem playing the game because the game will have a problem loading. Since the problem has something to do with the loading which is related to the flash player, the best thing to do is to update your version of the Adobe Flash Player.
Check first if you have this on your computer because if you don’t then really won’t be able to play any flash games.
To download the latest version of Adobe Flash Player visit Adobe.
Or if you are having a hard time downloading the program from their page, an alternative is to get Adobe Flash Player directly from Adobe | Direct Download – Adobe Flash Player.
Notifications
