dee dawson
20 points
Posted on - 08/29/2012
What I just want to do is just to scan my pdf file but then I was surprised when an error had occurred. Am I right when I reinstalled the software?
This is what I did because that has been the common thing to be done when encountering errors but unfortunately it had the same error again saying “The system cannot find the path specified”.
How do I reinstall it perfectly without having to commit the same error"E:setuphpzprl01.exe" -m ".autorun_network over again?
Would you mind sharing me how to resolve this matter?
I just want to do is just to scan my PDF file
You did right in uninstalling the software. There is really a problem in your software and I think there were files that the system cannot find. These files were very important for the program to function properly.
You should try to uninstall the program again and download another installer in the internet because I think there is also a problem in the installer that you are currently using.
Also, install that software to your primary hard disk “drive C” where most of the programs were installed so that you may not encounter problems in scanning, installing and using that software.
