Glenn Mason
Posted on - 09/22/2011
I would like to ask if this cssrs.exe error is dangerous.
Error
cssrs.exe – Drive Not Ready
The drive is not ready for use; its door may be open. Please check drive
A: and make sure that a disk is inserted and that the drive door is
closed.
Cancel Try Again Continue
It keeps popping up when I plug a flash drive or CD to the computer.
I constantly have to click cancel around 5 times before it stops popping up.
I keep getting cssrs.exe error
If you are getting errors like you are mentioning here, then your system may be infected with a virus or there is some kind of problem with your windows registry, which is causing this type of problems.
You should scan your system with the latest and updated Antivirus program and also scan your system with registry checking errors.
I recommend that you first use an Antivirus program; then registry checking program like registry booster.
RegistryBooster scans deeply in your registry and checks for errors and conflicts. It also optimizes and repairs system registry for good performance and stability.
You can use the software registry booster by visiting this link: Software registry booster
nosheen
This message is due to some interrupts' that are coming when your not safely remove the device or you eject the device while it is in processing.
You must remove the device while the work in done or then you must remove the flash safely.
