I keep getting error “ Rundll32 “
I'm using windows 7 ultimate 64bit operating system,and I keep getting an error saying
Windows Host Process Rundll32 has Stopped Working, never got this error before ,is there any way to resolve this problem?
Hi bella ,
Check for any malware running in your Pc first , I think your computer is under high malware attack .
I personally recommend using Kaspersky internet security 2012 for finding malware and delete them, download the trial 30 days version from the official Kaspersky website and the install it accordingly and then run a full system scan after installation respectively .
Now clear all your temp folder contents,
1. Go to start and then go to run
or Just press win key + r for shortcut
2. Type %temp% to open temp folder and then delete all the contents in it .
Now go to run again and then type msconfig
2. Go to startup and services tab in that check for run32.dll and uncheck it .
Now restart your PC and check if that error is coming again
Hope that solves your problem .
Here is the solution.
Download this Anti-Malware (free):
Malware Bytes from the following link
http://download.cnet.com/Malwarebytes/3000-8022_4-10804572.html
After installing Malware Bytes, update it then.
Scan your system to make sure it is clean indeed.
After performing above steps, scan it again with System File Checker and complete these following steps:
Hope this helps you. Let us know either way. Make it a great day!
