Need drivers for ATI Radeon AGP and Gigabyte Mobo
Hey there, it's an emergency. I lost my graphics driver CD. I operated Windows XP last night and now i am out of driver CD. I use a externel ATI Radeon AGP and internel Motherboard is from Gigabyte. Please is there anyway to recover this problem. What should i do?
Best Answer by Jamesmarshall
Answered By 0 points N/A #119593
Yes, There is a solution. You could go to the computer manufacturer's website and the download the drivers. Firstly , go to the computer manufacturer's website and there search for a drivers link . You could find that easily. Then , check your computer's product number and serial number. Enter the details of your computer like the computer's product number, serial number and the OS you are using. Then,check for graphics card driver  and then download that and install.
  • You could also check for the driver on the web. You could provide the details of the computer and the graphics card. Maybe , you could get a driver on the web itself.
  • Try the first one, because that's the official way. If not by both of these ways, then contact the computer manufacturer.
Cheers.
Answered By 0 points N/A #119594
  • You have many ways to solve this problem. You can download your necessary driver software. It’s really easy. If you not wants to spend money on this then you can collect your driver software from other source.
  • You have many sources. Find your motherboard’s series number and then find someone who using same motherboard. Then take that computer’s driver software and use this on your computer. It will match.
  • You also find it from computers shop. If they have that motherboard then they also have that driver cd. Take a copy from them and install it. It will work.
