jonsondevid
Posted on - 08/08/2011
I am using Microsoft 2000. Sometimes I need to check thesaurus option. But from last week I can’t access the thesaurus option. When I press Shift and F7 then it shows an error message. I clicked yes but after sometime it failed to re-install.
Error:
Microsoft Word
Microsoft Word can't open the thesaurus.
This feature is not currently installed.
Would you like to install it now?
How can I reinstall it ?
markus1d
I lost my Word thesaurus option
Hello Jonson Devid,
Lost thesaurus in Microsoft Word? Using updated version of Microsoft Word has auto spell check. Microsoft Word 2003 has option to manually activate thesaurus. This is a great help in making sure that spelling is 100% accurate and correct.
Here are the steps to activate and let you access the thesaurus features in Microsoft Word.
Go to Tools menu, look for Language and Thesaurus. This will let you access this feature.
A short cut options in Microsoft Word, you need to press Shift + F7 in your keyboard and Thesaurus window will be shows in the screen.
Look for an Thesaurus Icon in the upper part of Microsoft Word.
Hope this helps, feel free to contact us if needed.
mon47
I think your keyboard maybe disable. Recently I have experienced with our keyboard that was inactive. Do you know what is the activity of Thesaurus sub-menu? Or,what is the usefulness of Thesaurus in MS Word? I was actively working with Thesaurus menu once upon a time.
I was surprised to see and thought that we are in very need of Thesaurus. I hope you may observe to click on Tools menu. Then in language. You will then find Thesaurus. You can also use the buttons Shift+F7 if your keyboard is OK. You will start working with Thesaurus.
