I m getting error whenever i insert flash drive.
when ever i insert my flash drive into my pc it gives"write protected" message please help me to remove this message?
Hey Sana Sabir!
If you are getting this error then do not worry about this. I also had the same problem but I succeeded to solve the problem. I tried lots of software and commands to overcome the problem but i found myself with no luck. I then come to know about the HP USB Format Utility, I download and install the utility and i was able to solve the problem. I would like to recommend you the same software. That will help you a lot in resolving the “Write Protected” error message. You can search for HP USB Format Utility on the internet.
Thanks
Tunacao Caaron
Hi!
This is the solution to your question.
Write protection can be easily removed on flash drive by using Jetflash Recovery Tool v1.0.12 software. These are steps to follow:
1. Download Jetflash Recovery Tool v1.0.12 in your computer.
2. Install the software.
3. Connect or insert your flash drive to your computer.
4. Run the software and follow other instructions regarding the running of the software.
5. Unplug the flash drive and insert it again.
You will notice that there is no write protection, it has been removed.
Hope I solved your query. Good luck.
Hi Dear,
You should follow the below steps to solve your problem
Hope this solution is helpful for you
