I’m having Adobe linguistic dll Photoshop error
I recently installed Adobe Photoshop CS6 on my PC.  My PC runs on Intel Core i3 and Windows 7 64 bit.
When I launched the program, I received an error of "AdobeLinguistic.dll is missing".
I tried to uninstall then reinstall again but with the same results.
Anyone having the same Adobe linguistic dll Photoshop error?
Answered By 0 points N/A #129798
Hello maxine,
Regarding your problems it seems that your copy of Adobe Photoshop 6 may be a bad copy.
Have you re-downloading a fresh installer of the software.
You can also try this methods in fixing your problems.
1. Uninstall the software and Re-install it again.
2. Download the AdobeLinguistic.dll.
3. Locate AdobeLinguistic.dll. in the Adobe Folder and rename it to AdobeLinguisticBACKUP.dll
4. Once you have finish renaming the file. Copy and Paste the Downloaded AdobeLinguistic.dll.
5. Once that is done. Click and Start and type in "cmd"
6. Type in this command “regsvr32 AdobeLinguistic.dll” on the black screen
7. Then Press "Enter"
This method will solve your problem and replace the corrupt file in the software.
I hope that I managed to solve your problems. 🙂
Answered By 590495 points N/A #129799
That is not the usual error thrown by Photoshop CS6 because it is a missing file error. That problem can be caused by a corrupted file. If you already tried reinstalling the application and it didn’t fix the problem, you probably have a bad copy of the program. One possible cause is if you downloaded the installer from other sources.
Unfortunately, Adobe Photoshop CS6 is no longer available for online purchase. But if you previously purchased a retail licensed Photoshop CS6 but you no longer have the installation media, it is still possible to download a replacement installer. To download a replacement installer for Photoshop CS6, go to Download Creative Suite 6 Applications.
If you have a Creative Cloud plan and you wish to install Photoshop CS6, go to Download and install Creative Cloud apps. On the other hand, you can also simply download the missing or corrupt DLL file. Go to Fix adobelinguistic.dll error and download the DLL file. Here, it will show you different versions of the DLL file.
Since you are using 64-bit Windows 7, download one of the two 64-bit versions of the file. If the file didn’t work, download the other one. To install the file, unpack the ZIP file and copy the DLL file to the installation folder of the application requesting it, in this case, Photoshop CS6. Start Photoshop and see if it works.
If this doesn’t fix it, copy the DLL file to “C:WindowsSysWOW64”. Next, click Start, Run, type without quotes “cmd” then hit Enter. In the command prompt, type without quotes “regsvr32 adobelinguistic.dll” then hit Enter. Restart Photoshop and see if it works.
