I’m having Apple login problems
I have recently upgraded to OSx Mountain Lion from OSx Snow Leopard.  I also updated my iTunes to the latest version 11.0.2.  Ever since the OSx upgrade and iTunes update, I now can't log into my Apple account and having an error of "This Apple ID has been disabled for security reasons".  I need help in Apple login.  Thanks.
Best Answer by James V Rose
Answered By 80 points N/A #147552
Hello Davis,
If your Apple ID is disabled for security reasons then visit the website to reset your account. This will help you to log into your Apple account and ITunes. Plus you can also reset your password by clicking on “Reset Password” or “ Forgot Password? ”
Ronald M Peterson.
Answered By 50 points N/A #147553
Hello Avon,
You have to reset your account in order to log into your apple account and Itunes. In order to do that you have to visit there website to retrieve your account. Also it will helps you to change your password into a new one for safety. My advice to you is to go to there website and reset your account.
