I’m having Error 324 while burning DVD-R
I am getting DVD read error 324 οn thе Wii backup loader channel. What is this? I'm getting іt when I'm burning DVD-R’s with ImgBurn аt 1x?
Please help.
Please help.
Hello Charles Bowers,
This problem has occurred either because your DVD-R recognized a bad media or it was a case of bad burning or there were no cIOS. Use the DVD-R disks for burning at slow speeds of either 2x or 4x using imgburn. This is the resolution for fixing this error 324 DVD Read Error.
If the problem still persists, clean the device carefully and then uninstall and reinstall the driver software and make sure that the device is connected correctly. If the problem still continues, take help from an IT Expert or contact customer service of your device manufacturer company. Hope your problem gets fixed soon.
Best of Luck!
Hi Charles,
That's most probably an error due to the burning of the DVDs on the Wii machine. It is not a most common device to burn DVDs.
However you can look for the latest files from the website.
Or the cIOS installer.
You can also increase the speed and ensure you are using good disks to write about.
Try rewriting the DVDs and see whether it works well. It should work.
I hope this helps.
