I’m having Oracle Forms word processing input problems
Hello.  Please help me out here.  When I was using Oracle Forms 6, I had no problem pasting data from Word and Excel to Oracle Forms.  I am now using Oracle Forms 9i and I could not paste any word processing application data into it.  Can someone help with my Oracle Forms word processing input problem?
Answered By 0 points N/A #138849
Hello Dorindagmincey,
First of all you need to be sure that you have installed the product correctly. Once you are sure that the installation is fine, check out the configurations and double check to make sure that the configurations are fine. You may refer to the installation/user guide that comes with the product or go to the product’s website to access online help.
Now coming to the problem you are having with Oracle forms, there are a lot of possibilities that might be causing the trouble. It's not quite possible to list all of them here, but here you will find all the details and the solution to your problem.
