Hey guys! I tried installing the latest version of PowerDVD12 and I can’t seem to do it right. Below is a screenshot of the error message:
InstallShield Wizard
Required installation file is missing (7z.exe).
I need some help here. I hope someone knows a fix for this. Thanks!
I’m having problems installing PowerDVD12
Hi guys!
Following description may solve your problem. I think copy you are using may be corrupted. Or same copy must be checked in your system. Go to control panel, click on ad/remove button then remove powerdvd and restart your computer. Now enter disk or source file and install powerdved 12. Follow step by step installing instruction and finish installation. This time you may not face above mention problem.
But If you see same error message during installation. then change your source file that means fresh new disk, or pendrive must be recopied for complete file. I hope you will be able to install powerdvd12 after studying this probable solution.
If you are successful in this job don't forget to rate me. Happy nice day.
