I’m having problems using Aligned section view in Solidworks.
Posted on - 06/29/2012
I am using Solidworks 2011(SP-2) and I get the following error as I try to aligned section view.
Here is the screenshot of the error.
The model could not be properly sectioned by the section line. Please check that the section line cuts through the model/components. The components which are falling in the section are: OK_200041-1
Please give me your suggestions.
Thank you.
