bryan dowdy
40 points
Posted on - 04/05/2013
I just installed Secunia Personal Software Inspector 3.0 with Netscan to complement my Avast Antivirus. I try to open a URL and it gives the message "an error occurred while attempting to open the specified URL". Anyone having the same PSI Secunia NetScan problem?
I’m having PSI Secunia NetScan URL error
Hi Bryan,Â
First of all, stop PSI Secunia with the Task Manager, and then go to Control Panel and uninstall it. There were some bugs in v3.0, so you can try downloading it again and check if the issues are solved. Then, install it again. Maybe you can try to change the antivirus software, because Secunia had problems with some of the antivirus softwares. I heard that it works worst with NOD32. But my experience says that the v2.0 was the best, and I personally, still use it.
Best.
