Hello. I'm trying to learn about websites and webpages by myself. I want to know more about HTML, Java, Graphics embedding. Is there a free technical online test where I can check my skills? Thanks.
I’m looking for a free technical online test
Hello there Caroline,
There are a lot of sites that you can use in the internet if you want to learn HTML and they can give you all the information you need to boost your learning. W3Schools gives a lot of tutorials when it comes to learning HTML and other aspects of web programming. Just go to https://www.w3schools.com/ and learn a lot there.
Hope it helps you.
Regards, Roland
There are many internet site that offers and can give you a free technical test. You just need to read and pick the right or appropriate test that will suit your needs. Here the two sites that I can recommend:
https://www.wiziq.com/tests/it-technical-test
It is an online practice test where you can find different exams or test on different fields. You just need to register using your Facebook account or simply fill up the form on the site
https://www.skillsign.com/
This is an online testing also where you can easy to customize by going to the settings. You don’t need any installation. You can easily get the result and analyze the findings which also secure and confidential to your account only. All you have to do is to register also and find the write exam for you.
