Hi. I'm trying to create a website and I need a Joomla simple template with user customization where I can use CSS within the template design. I'm on Windows 7 64 bit. Any help would be highly appreciated. Thank you.
I’m looking for Joomla simple template
Hello there Jhon,
I know making website using Joomla CMS is not an easy task especially when considering the design or the template you would use. Gavick offers you a lots of template for your Joomla, and it is really helpful to what you need.
If gavick.com does not fit to your taste, click here for another link that you may want to visit.
Hope this helps you.
Regards, Roland.
Hello Jhon Anderson,
Creating a good looking website is not an easy job to do. It is really a challenging job.
You have to do the hard work for that.
You are looking for a simple Joomla template with user customization.
Click here for some simple templates.
I don’t know how much it helps you.
Hi Jhon! I know how to build websites using Joomla templates. I use free Joomla templates from this website. Because they do produce good templates you can download totally free and edit it by your own way, but be sure to credit the programmer/designer of the template by not removing his/her name in the Make sure you check your Joomla version installed in your PC before you download any of the templates. Example, some templates are for version 1.5x, some are for version 2.0x and 3.0x, respectively. You can edit the CSS of the Joomla Template you chose. I hope this works for you smoothly. css file.
