Hi. I am looking for help regarding a Fortran error message that I have encountered. The error message number that I am referring to is: nnn
Here is the statement of the error: ‘The Intel Fortran message catalog file was not found on this system. This error has no condition symbol. ‘
Please provide me a solution for this.
I’m receiving Fortran error message
Hello Bray Slattery, this issue worries many other users like you. But do not worry, this is not a problem to affect your work. The error code nnn indicates that it is not a fortran error and it is not returned by IOSTAT. It is just for information purposes only. The program will continue. But incase if it does not continue, it is recommended that you uninstall the program including its registry files from the system and reinstall the program again. That should fix it completely. If the problem persists, contact an IT Expert near your area. Hope your problem gets solved soon. Best of Luck!
