belensienna
10 points
Posted on - 08/24/2012
I want to install the 7 zip ubuntu free download. Can anyone tell me how to get it through internet free of cost? Also tell me the procedure for installing the 7 zip ubuntu. Hope so someone reply for my question along with the solution.
I need 7 zip ubuntu free download.
You can download the 7-zip tool from the below link which I have provided. It is a free tool which is available online.
http://www.7-zip.org/download.html
I will guide you how to install that tool on your system.
To install the 7-zipÂ
choose the Applications menu in that you will see Ubuntu Software Center
Choose All Applications from the view menu.
enter 7-zip in the search box provided and search by pressing enter key.
It will list the 7-zip tool.
Select that and click on install which will be shown at the bottom of the description.
It will install the tool on your system and you can use it now.
Similar to WinRAR and WinZip, 7-Zip is another file compressor which offers high compression ratio than the first two. With WinRAR, the resulting archived file is a RAR file (.rar), for WinZip, the output is the popular ZIP file (.zip), and for 7-Zip the output file is the 7z file (.7z).
Unlike WinRAR and WinZip which are commercial software, meaning you have to purchase them to get the full functionality, 7-Zip is a completely free file archiving software. You can download and use it for free. To get the latest version, go to the 7-Zip Home Page.
7-Zip supports Windows XP, Windows Vista, Windows 7, Windows 8.x, and Windows 10 including Windows 2000, Windows NT, Windows Server 2003, Windows Server 2008, Windows Server 2012, and Windows Server 2016. If you have Linux, download p7zip instead. This is the port of the command line version of 7-Zip for Linux and Posix.
