I need ABBY fine reader batch processing tutorial
I'm using ABBY FineReader Pro 8.0 with the Optical Character Recognition to batch process JPEG document images from a digital camera but I could not save it to a PDF file format.  Am I doing something wrong here?  I need ABBY fine reader batch processing tutorial in Windows 8.  Thanks.
Best Answer by Dawn Johnson
Answered By 0 points N/A #166451
Hey,
I can surely solve your problem by giving you some tutorials and videos where you can do scanning settings, page out analysis, using block templates, recognition speed, etc.
You can also refer to user languages and language groups and can customize ABBYY fine reader toolbars.
http://informationworker.ru/fr8tutorial.en/Tips.htm
I hope this will solve your issue.
Thanks & Regards,
Gillam Janetj
Answered By 0 points N/A #166453
Hello there !!
As you have said that you are using ABBY Fine Reader Pro 8.0 with the Optical Character Recognition to batch process JPEG document images from a digital camera but it could not save it to a PDF file format. So what  might be happening that your document that you want to save it to the Pdf format is not a valid document format according to the file system. So i suggest you to find the compatible file system that supports the embedding of your document into a valid file format.
