Hi. I'm a multi-tasking kind of person and I would like to know if there is an active program time monitor for all the applications that are open? I would also like it to track time for network traffic in LAN. I'm on Windows Vista 64 bit. Thanks.
I need active program time monitor
Hello, Meagan
Hope you are fine. Don't worry , hope your problem can be solved.
Yes there is software which are you looking for. Active Wall Traffic Monitor 4.0 is a traffic monitor software for LAN. At the same time more than 1,000 computers is monitored by this software. It is helpful to monitor
Speed
Packets bytes of each computer and
Provides traffic statistics
Net flow.
Download Wall Traffic Monitor
Hope you will get your answer.
