I need add ons excel find broken link
I have a large and important excel workbook. Many files were hyperlinked. Currently the files are not located in the same location when the excel files were created. Some files have been moved because of a system problem. So I am seeking for add ons excel find broken link. I need a add ons that can find and fix problems related to me. Please help me.
Answered By 0 points N/A #182625
Hello there Alland,
There are add ons which will fix your issue, but unfortunately everything is priced.
If you just want to use it for a single purpose then you can used the trial version. Since everything is priced, I would suggest you to try the DigDB, an add-on for Excel elitists. It is considered the best in the market and is giving a trial version for 15 days.
Its main features which would interest you are:
  • Finding Cell with broken links
  • Break those broken links to maintain the functionality of the file.
You can find the rest of the details about the add on here in their official website.
A demo of a scenario along with the working of the add on is also given there.
I hope this helps you in your problem.
Cheers.
