I need Afterlogic webmail export contact to Outlook
I use AfterLogic Webmail Pro PHP in my POP3 mail server.  I need AfterLogic webmail export contact to Outlook.  Do I have to convert it first to a CSV file before exporting to Outlook?  I'm on Windows XP 64 bit sp2 and I use Microsoft Outlook 2007.  Any help would be appreciated.  Thanks.
Best Answer by Derek A Rosas
Answered By 20 points N/A #148555
Hi Caspian!
This process is quite simple. Just take a look into awm_addr_book database table and it should give a clear insight. In some phases, this credentials page might be helpful as well.
There are a couple of other tables used by Contacts section of WebMail: awm_addr_group maintains list of contact groups while awm_addr_groups_contacts holds the information for each grouped contact about the group that contact belongs to.
Answered By 60 points N/A #148556
Hi Caspian,
As Darek mentioned above you can export your contacts from awm_addr_book this database table into a CSV file and then moving into outlook 2007 you can import the csv file with very ease. Follow the instructions:
File->Import/Export->Import and all your contacts will be imported into Outlook 2007.
Please let me know if you have any queries. Thank You.
