I Need An Assistant To Fix The Acpi Sys 0xc0000098 Error Code
When did the Acpi sys 0xc0000098 error code appear in the system? Explain the methods to troubleshoot the error code.
Acpi sys 0xc0000098 error code is a BSOD error that occurs when the user upgrades or clone OS to Windows 10 and receives this error with the error message ‘Your PC/Device needs to be repaired. The Windows Boot Configuration Data File does not contain a valid OS entry. File: \Boot\BCD. Error Code: 0xc0000098.’
The methods to fix the problem are as follows:
Method 1: Run Startup Repair
Step 1: Boot the computer with a Windows recovery disk.
Step 2: Follow the installation wizard, then click on Repair your computer to enter the Windows recovery environment.
Step 3: Go to Troubleshoot >> Advanced Option >> Startup Repair.
Method 2: Check Disk
Step 1: Enter into Windows recovery environment to open Command Prompt window.
Step 2: Enter the command chkdsk c: /f. then, an error will be fixed automatically if it are detected.
