I have a 15" Retina Display MacBook Pro that has a 2.4 GHz Intel Core i7, 8 GB RAM, Intel HD Graphics and OSx Mountain Lion. I downloaded the Viral Submitter Pro for Windows. Do I have to install VMware for this to work or do I just download another Mac article submit program?
I need another Mac article submit program
Hi Gregory Manilov,
Its great for you to use Viral Submitter as it is a great tool. With regards to your question you can install a VMware on your Mac machine for you to use Viral Submitter Pro in windows as it is designed to be used in Windows OS.
However if you would want to not use a VMware you can also get a Mac version of ViralÂ
Hope it will help you.
Thanks
Hello Gregory,
Just to clarify, yes you do need to download a virtual machine if you want to run the Viral Submitter Pro for Windows that you currently have with you since you have a MAC. The easiest way is to download the Viral Submitter Pro MAC version mentioned in the previous comment. I hope I made everything clear.
Sincerely,
Luz M Terry
