I need an Antivirus HP java zip that is reliable
A friend sent me a zip file that contains a ton of Java games thru email.  I unzipped the file using WinZip and I was shocked that it contained the 42.zip zip bomb virus.  I have a 32 GB HP Touchpad with Qualcomm APQ8060 Snapdragon chipset.  I need an antivirus HP Java zip that is reliable and accurate.  Can someone help?
Answered By 40 points N/A #171031
Dear Simon,
Your friend has done very bad thing. Any way i recommend you to not open that zip file until you scan it completely.
There are a lot of Antivirus software that can remove the virus. You can choose any one but only latest version and updated.
i suggest you to use Avast Antivirus in this situation.
Because it will delete all the files having virus coding.
Please download the Avast antivirus from this link as soon as possible to make your computer secure.
https://www.avast.com/index
Thanks
