I was just wondering how these .exe files are so easily installed on our computer then my brother told me that there are many software which are application exe maker. I asked him if he knows any software but he did not know any of them.
Can you please tell me from where can I get application exe maker software?
I need application exe maker software
Hi Leona E Miller,
To make a .exe file firstly you should create a .bat/ .Py etc. file then you can convert them into .exe file. Your brother is right there are many .exe maker software on the net which you can get free or you should purchase them. But before create .exe file you must create an another file format. I am giving you a link where you can get them easily and may be free.
http://www.softpedia.com/hubs/EXE-Creator
Best of luck
Hello Miller,
Hey the executable (.exe) files are actually used on windows platform, so these are package files which install the particular application on to our systems. Well I also once want to develop applications, in order to do that I searched a lot on the internet and came across a software called the Smart Install Maker. I think you must try this too.
http://www.sminstall.com/
