I need an application for garmin img reader.
I need an application for garmin img reader. I need a Garmin img file reader for I have some files that has an img extension name and it is very important to be read or open. For some reasons that I don’t know why my first installation was unfortunately a failure. I hope you can give me another way to get this done successfully.
Thank you.
Best Answer by Elgaothy Carl
Answered By 5 points N/A #178524
Hello Bryan,
.IMG is a type of CD / DVD image which is quite similar to the .ISO files.
It might be contain the replica image of the contents of a CD/DVD.
There are various freeware available in the market nowadays which can help you explore your .img files
I would DAEMON tools free version or Imagine software.
Apart from that other software that can be used are Magic ISO and Virtual clone drive.
Download and install any one of them and mount your .img onto the virtual drive to read it.
Answered By 0 points N/A #178525
For you to be able to achieve your goals, you must get the most recent version of MapSetToolkit or you will run into errors. Plus you can download it here https://sites.google.com/site/cypherman1/
After downloading the MapSetToolkit, follow the simple steps to complete the installation process. It is as simple as 1 2 3 4.
Alternatively, there is another free program called GPSMapEdit, it will also solve your problem. If you have any problem, don’t hesitate to ask. Good luck.
