hannahwtc
10 points
Posted on - 03/25/2013
Hi. I have AutoCAD 2008 on a Windows Vista 64 bit system. I'm trying to learn AutoCAD and I was wondering if someone can give me the AutoCAD 2008 commands list PDF file? Any help would be much appreciated. Thank you.
I need AutoCAD 2008 commands list PDF format
Hello Hannahhwtc,
Download AutoCAD 2008 commands in PDF format. Another alternative link for commands. You mentioned you are learning AutoCAD, so here are some useful tutorial links which will help you in the learning process. Also check out AutoCAD 2008 Essential Training video tutorials.
Hope this helps. Happy learning. Best regards.
Greetings Hannawtc,
I've searched for you and found some good tutorials for Autocad in .pdf.
If it opens in browser for you and you need to move it somewhere just
press download in the top right corner of your screen. An icon resembles
like this.
On my screen is black and white though, it might be different on yours.
depending on the version and settings of your Adobe Acrobat Reader.
This link provides you with some command basics.
I'll give you one more and this one is a 3D tutorial.I hope this helps you,Regards.
