Hi everyone,Â
I am using AutoCAD. I need a software for drawing, printing, saving on AutoCAD. Is AutoCAD drawing viewer software useful for this purpose? Please give me some suggestions about this.Â
Thanks in advance.Â
I need AutoCAD drawing viewer software
Hello, Charles.
You can download and install the software from the following link: https://www.autodesk.com/products/design-review/overview. Maybe you''ll see the names on the Internet such as DWG TrueView or Autodesk Design Review software. It's the same thing. We are talking about a free .dwg viewer built on the same viewing engine as AutoCAD software. With this you will be able to open .dwg files, view, print and track changes to Autodesk 2D and 3D design files without the original design software.
Hope you''ll be satisfied, if there are some problems feel tree to ask our team.
Regards
