I need autocad unicode font descriptions for my different languages
Hi friends,
Now a days, I have started the learning of AutoCAD. I am basically a student and want to draw some civil drawings on AutoCAD. I also need to learn autocad unicode font descriptions. I have to use the different language's font in drawing, according to the client requirements or a language that Drawing readers can understand easily. Your help in this regard will be heartily welcomed .
Answered By 0 points N/A #166618
Hello Groat,
AutoDesk has done a beautiful job of documenting every small task and feature in AUTOCAD. Since you have just started learning AutoCAD, now is the best time to go through its documentation regarding unicode font descriptions. You can get it at the official AutoDesk documentation.
Also there is an ebook regarding shapes and Fonts of AutoCad. You can download the ebook here. I hope these two resources should suffice in helping you gain an understanding regarding unicode font descriptions. Cheers.
Answered By 590495 points N/A #166619
If you are a student and eager to learn about AutoCAD, try the following online tutorial for AutoCAD.
MyCADSite – provides free tutorials for AutoCAD students. The lessons are intended to be compatible with as many versions of AutoCAD as possible. The lessons on the site are based on AutoCAD 2010 but are modified for other versions such as the AutoCAD 2015. Since surely there are differences, they are noted in the text. The lessons are divided into 4 different levels. Level 1 is the getting started level. Level 2 is the intermediate. Level 3 is the introduction to 3D. Level 4 is the advanced topics.
If you want to download AutoCAD, visit Autodesk Software for Students. Download AutoCAD so you can practice the techniques and the methods in the lessons.
