Hi. I have a lot of MKV files that I would like to put on my iPhone.Â
I need an automatic encoding mp4 software that does not compromise quality.Â
I have the 32 GB iPhone 3GS that has the 600 MHz Cortex-A8 CPU, PowerVR SGX535 GPU and iOS 6.1.2.Â
Can someone help?
I need automatic encoding mp4 software
Greetings Marvey Logan,
For this purposes you can use numerous software. What most people recommend is using YAMB.Â
On the download page select
Yamb-2.1.0.0 beta 2 with installer (recommended for most users). Click on the icon left of it.
The user interface looks like this
Double click the highlighted option and then click +Add and add your mkv video. In the bottom it will show the Output of your mp4.
Click Next and the software will start converting . Check the results and see if they work for you.
I hope this helps,
