I have a Nokia 500 that has 1 GHz ARM 11 CPU and Symbian Anna OS. I need an app where I can save my contacts, files and SMS messages on my desktop for backup. Can someone tell me where I can download a backup application for Nokia 500?
I need backup application for Nokia 500
I would recommend you “EZ Backup Opera Basic 6.32” . This is an amazing application which makes easy to backup your contacts, mails and Opera bookmarks. This utility tool is the best app for your Nokia phone as well as for your Symbian OS. You can also download Backup Opera 0.2 which can be used for the important folders and file backup. A download link is given below.
http://opera.softpile.com/opera+mobile+8.65+full+flash+7+nokia+500/windows/backup-tools/
Hi William S Snell,
While their are many apps in backing up your files in Nokia phones, Alternatively, Nokia itself have a free software that you can connect your phone and PC, and transfer contents. With Nokia PC Suite you can backup your phones settings, messages, contacts, synchronise music, photos and other files and be able to restore the backed up files using the Suite.
Hope this helps you.
Thanks
