The problem is I have many contacts,notes and files that I want to backup.
I don't have an application for that, at least not a secure one. So what I require is for you to tell me where can I find a backup application for Nokia 500 that is secure and will definitely keep my files intact.
And also, a little help with the process would be nice.
Thank you very much.
I need a backup application for Nokia 500 phone
The best option for you to backup your files would be Nokia's own Nokia Suite.
You can download the software from the following link :
https://www.nokia.com/en_us/phones/support
How to setup:
1. Download and Install the software onto your PC/Laptop
2. Connect your Nokia 500 using a data cable to your Laptop/PC and select the backup option from the software.
3. It will give you options as to what you want to backup and you can simply select the desired options.
It is hardly a ten minute process and will keep your files secure with a reliable software.
