I have a Dell XPS 17Â that has Intel Core Duo, 4 GB RAM, 1 GB NVIDIA Video Card, 1 TB HDD and Windows OS 7 64 bit.Â
The battery seems to drain faster than my other laptop.Â
Is there a battery economy program for my Dell?
I need battery economy program for my Dell
Hello Albert D White
There is a certain life of battery, because this is a consumable part of the laptop.
Generally battery life is from 2-3 years. After this much time they start to give slow performances and drain faster.
If your battery is new and still drains faster, you can ask for replacement from Dell.
Below is the link where you can learn some cool tips to maintain your battery and extend its life
Tips to extend battery life
However if you want applications to save battery , I'll provide a link of few free downloads. Goto this websiteÂ
Hope this information would help!!
Thanks
Bennie
Hello Albert D White,
You can use NHC (Notebook Hardware Control) to gain good performance from your Dell battery.
NHC controls the hardware and system power management, prolongs battery life, cools down the system and reduces the power consumption. It also monitors the hardware to avoid system failure. Download it from here.
BatteryCare, Another good software for your laptop. Monitor and Configure your laptop battery, Track the discharge cycles.
It helps you to keep your battery calibrated, thus prolonging its life considerably. Get it from here.
If these tools don't improve your battery condition then you should consult proper technician or replace the existing battery.
Hope this helps.
Best regards.
