Walter Neff
30 points
Posted on - 10/17/2012
I have a Samsung smart TV, which i have been trying to edit the channel list without much luck. I need a tool that i can export the channel lists from the TV, into the editor to sort them out and edit the channel lists for easier identification. Any expert who knows Samsung channel list editor best?
I need the best Samsung list editor?
Hi Walter Neff,
You are trying to edit the channel list without much luck in Samsung smart TV. You need a tool which will help you to edit the channel list. There is software which can help you. First you have to download and install it.
Here is the link: https://sourceforge.net/projects/samschanneledit/.
I see you haven't had much luck editing the channel list. It's not so difficult.
Please follow the steps I have given below:
1. Press the "SMART" button on your remote.
2. Go to "Channel" (choice with satellite dish).
3. Find the channel you want to edit.
4. Press the "Tools" button on your remote and choose an option.
Please inform me if my method doesn't work. Enjoy!
