I need to download free bizagi quiz for windows to create Flash-based quizzes and surveys with multimedia objects. Also I need to create the quality process documentation in word or PDF and export or import the process information from Visio or XML. Could you advice me the software for that?
I need bizagi quiz for Windows.
Hi Nancy,
I think you want to create flash based quiz website, so you need bizagi quiz for windows. I will give you some effective bizagi quiz software info with download link.
Wondershare QuizCreator is a versatile software tool designed to help teachers and trainers to produce Flash-based, high-quality exams and surveys.
Adobe Captivate Quiz Results Analyzer: Adobe Captivate Quiz Results is developed by Adobe Systems Incorporated and is used by 1 users of Software Informer. The most popular version of this product among our users is 1.0.
The name of the program executable file is Adobe Captivate Quiz Results Analyzer.exe.
Thanks for asking.
Regards
