Hi there,
 I'm looking for a business logo generator wherein I can edit the graphic and text of the generated logo and saved as a JPEG file format. A third party software or from the web would be fine with me.Â
Any suggestions?
I need a business logo generator
Hi Carolyn,
There are many logo generators / editors available online, you can make use of it. One best solution I would suggest is to download this software and try it.
http://www.sothink.com/page/logo-design/logo-maker-save-your-time.html
You can create, edit the text of a generated logo and save as JPEG or PNG format.Â
Hope this will help you to get the tool you are looking for.
Hi!
There are many types of business logo generator. Here is a list of 7 affordable or free logo maker tools:
1. Logo Maker = free, but must pay $ 49 for high resolution logo.
2. Logo Yes = must pay $69 for the high resolution logo.
3. Logo Ease = free. It helps create the high resolution files without any extra fees.
4. Free Logo Services = free , but to purchase high resolution logo $39 is a must.
5. Cool Text = completely free.
6. Logo Snap = basically free. Ask for a little donation to make sure this company keep on going.
7. Mycroburst = must pay $19 fee to use this service.
