Hi guys. Can someone suggest a check mail server tool that I could use? I need to test if my SMTP mail server is working correctly and efficiently. My outgoing connection to TCP port 25 keeps getting blocked. I use Microsoft Exchange Server 2007. Please help. Thanks in advance.
I need a check mail server tool
Hello Claraj,
You may try to use Wormly to check your SMPT mail server. Wormly has a simple, few useful free tools to make your life easier. It has a free trial for the new users like you. Wormly also have phone, email alerts to keep you in the loop when failure strikes.
Hi Claraj,
Below are the suggested list of Mail Server Tool that will aid you in your issue with SMTP mail server:
Toolheap's Test Mail Server Tool – This is full featured mail server emulation offers the web programmers or developers, even ordinary users test their mail server. SMTP port 25 will be the based in program's port to listen on. It is easy to use, small size and you can specify a folder to store received messages.
Mx Toolbox's SMTP Diagnostic – This web page offers the user to test the connection of mail server via SMTP by performing an Open Relay Test internally. This application also measures the response time for the mail server.
DNS Stuff's Mail Server Test Center – It allows the user to manage and monitor email and will save time when troubleshooting email issues. They have free trials on checking email issues.
Web Wiz's Email test Tool – Allows the user to the test the mail server and MX Server setting. You only need to input your email or domain and select whether IPv4 or IPv6 for connectivity to the Mail Server. Then you can ultimately run the application by clicking the "Run" button.
DNS Exit's Mail Server Testing Tool – This web tool allows the user to configure your email server at the specified SMTP port. This will also deliver the message to your email server and helps you configure your email server correctly.
Hope this aids you in your dilemma.
