I need a clarification about MS Access Developers activex
Hello I am Kristopher.
I read a lot from different forum and blogs and I’m here to ask you about Microsoft Access and ActiveX.
I really want to know how to add a Form Splitter Bar using ActiveX or an ms access developers ActiveX.
Can you help me?
Thanks a lot.
Best Answer by Harrington Curtsinger
Answered By 0 points N/A #177566
Hi Kristopher.
With regards to your queries on how to add a Form Splitter Bar using ms access, here are some tips on how doing it. You can use the splitter control it provides automatic resizing of controls on your MS access form.
The splitter control is very easy and intuitive to use.
Place the splitter control on your form and specify if it is horizontal or vertical, Position and adjust its length between the controls you wish to resize You can specify what color of the splitter bar will be and the length values for its location. If you’re still not satisfied with how to fully operate it, you can simply go to Fmsinc for the free tutorials on how to add a Form Splitter Bar.
I hope it helps you greatly.
Answered By 0 points N/A #177568
Hello Kristopher,
ActiveX provides custom controls that are designed specifically for use with Microsoft Access. These controls support all versions from Access 2000 to 2010 including the 32 and 64-bit versions as well which makes your database look impressive.
Total Access Components offer you 30 controls to develop powerful and functional MS Access applications. Other strong features and more details with examples on how to add a form splitter bar can be found here.
Hope you might find this useful.
Answered By 0 points N/A #177570
To add a Form Splitter Bar using ActiveX or an ms access developers active you must specify whether it’s vertical or horizontal and then you must add the splitter control on your form.
You must need to adjust its length and position between the sizes you desires to have.
Splitter bars can also automatically adjust the controls.
