I have a new genesis tablet and was wondering if could connect adb to genesis tablet? I am new to this and need expert advice. I am currently planning on consulting it to an office store but I need at least basic knowledge so that I know what I would as further if I do so. Thanks.
I need to connect adb to genesis tablet
Hi Kylie Caseey
If you want to install ADB drives on your new Genesis tablet, First determine either you have 32bit or 64bit windows.
The program of installing ADB is found by following this link: www.topnotchtablets.com/installADBdriver
Incase your window has a problem of getting this staff work not able to connect USB devices, the aggravated problem can be fixed by following this link: www.topnotchtablets.com/FixUSBproblems
You can now enjoy using your New Genesis Tablet.
