I need to convert jpg to icon file
I have a project going on and this time I am ask to create jpg file to an icon file. It will be used as a favicon of a specific website. Now, I would like to ask. What is the best way to convert this jpg file to an icon file? Is there special software that can instantly convert jpg files to icon files? Please tell me how to convert jpg to icon file.
Best Answer by shubh1
Answered By 0 points N/A #155603
Hey Stepheen,
There are unlimited ways to convert images from .jpg to .ico (icon) formats. You can find free or paid applications, easy or professional user interfaces, long or shorts ways. The way I would personally convert jpg to icons is the following:
Go to http://images.my-addr.com/converter_jpg_to_png_online_freeware_tool.php and convert your jpg to png format. Once converted, go to http://www.convertico.com/ and convert your png to icon format.
That above method is free, easy to use, and no need to download anything.
Answered By 0 points N/A #155604
Hi Stepheen,
There are various software available online that can be used to convert .JPG to .ICO files. One of them available online is http://www.prodraw.net/favicon/index.php.
Just go to this site and upload any image file including .jpg file that you are asking and get it converted into .ICO file of your choice of size as well.
Alternate solution:- Open your .JPG file in any image editor like MS-Paint and follow the instructions below.
1. Open Microsoft Paint and select "File" and then "Open" from the toolbar menu. Select the file and then click "Open."
2. Select "File" and then choose "Save As" from the toolbar.
3. Type a name for the file and add ".ico" to the end of the file name.
4. Select "GIF" as the "Save As Type." Close the file.
5. Re-open the file by selecting "File" and "Open" from the toolbar. From the "Files As Type" drop-down list, chose "ICO(*.ICO)."
6. Locate the icon file and press "Open."
Hope this helps.
Thanks
Shubham
Answered By 0 points N/A #155605
Yes, there are many free websites on the internet which provides the services of image conversion. Many software are available online, which can be used to convert jpg files to icon files. You can find these site on Google and I am sure such sites would be very helpful for you regarding this purpose.
Thanks
Answered By 0 points N/A #155606
I suggest you to download “JPG to Icon Converter”
JPG to Icon converter is free and it is very easy to use
It’s contain simple interface so any one can use this software without any problem
Its convert files into 16 x 16 icons and 32 x 32 Icon
If you want you convert you JPG file to icon online.
It’s totally free & no download needed.
Website: https://image.online-convert.com/convert-to-ico
 Thanks & Regards
Mckinney Ma
