Hi there. I just received an SVG image file created with Inkscape Version 0.48. Is there a convert online SVG to XML solution that I could use? I don't want to install a software to save disk space. I use Internet Explorer 10. Any help and suggestions would be much appreciated. Thanks guys.
I need a convert online SVG to XML solution
Hi Eleni,
Unfortunately there is no SVG to XML converter present online. There are some that claim to do the task, but they are not reliable and cannot be trusted, so its always better to use conversion softwares like Exchanger XML Editor for this purpose which produce quality results and are safer to use.
If you are avoiding softwares just because of the amount of the disk space they will acquire, then you can always uninstall them after the conversion task is done and hence releasing the disk space that the software used.
Greetings,
I understand your need for an online SVG converter. I've scoured the web for such, but I'm afraid there's none. If your primary concern for your aversion to software is the amount of HDD space it will consume, I'd recommend Exchanger XML Editor.
It supports viewing, editing and converting SVG contents to other formats like PNG, JPG, and TIFF, for very little HDD space consumed.
You can always uninstall it if it will not meet your needs.
