I need to create javascript form mail xml?
I am working with my project right now using XML.
Can I create JavaScript form Mail XMLl?
Can you give me an idea on how to do it?
The form will be a login form for users having only a password, username and a button.
Please help.
Thank you.
Best Answer by Jhon Nahoana
Answered By 0 points N/A #137158
Hi Brown,
You can easily make it easily here is URL with detail information including scripting step by step which helps you to understand all steps one by one check this link it contains
1: Login.jsp
2: Web.xml
3: Struts-config.xml
4: Login form.java
5: Login Action Java
6: Application Resource Properties
Complete solution in one page
Answered By 0 points N/A #137159
The problem you are facing is easy to solve, I ran across a site the other day that will help you.
Go look at the given link, it has all the details you need to create the JavaScript form mail XML.
You will solve your problem in no time.
Thank You.
