ted hitz
20 points
Posted on - 02/12/2013
Hello programmer,
I am newbie in PHP. I want to develop a program that can scan the network and port too. I am searching for the php program network scan. I hope some PHP experts can understand my question. Waiting for a PHP code or solution from the PHP experts. Thanks for your help.
I need to develop php program network scan
You can develop many web related program through PHP/Javascript. Generally, this kind of languages are used to create or develop web design software. You can also think about another program wireless network scanner. I give you a link that will provide you the PHP Script IP Network Scanner. Follow the link: http://www.filebuzz.com/findsoftware/Php_Script_Ip_Network_Scanner/1.html
Hope, this will help you. Thanks.
If I'm not mistaken you want to scan your network and ports. Here is a script that will allow you to scan your port, IPs, URLs and more. Just insert it in your Notepad and save it as portscan.php and then upload it.
