Hello experts,
I need a disk empty space cleaning software. For I know there are some hidden viruses that may harm the computer system or registry. There is some disk that I already formatted a while ago and I want to clean that disk empty space to be sure that all the hidden objects will be removed.
I need your help on how to get a free disk empty space cleaning software.
Thank you.
I need a disc empty space cleaning software.
Hello Curtis,
To ensure that your disk is clean and free from virus, you can simply format the disk. To format a disk you don't need to download any kind of software.
If you are a windows user, go to my computer> Right Click the drive you want to cleanup > Select Format from the drop-down list > Check the quick format check-box in the new window opened > click 2 times ok > After receiving a Format successful message all the files including the hidden ones are removed from the disk.
Hello Curtis Marry,
You can download cleaning software to empty your disk space. Here are some cleaning software names and addresses where you can download it.
Then you can install the software and solve your problem.
