Hello Experts,
I need to download free registry clean software.
Some viruses will first attack the computer system registry and it is important to protect our system registry for a security purposes and to prevent file damaging errors.
I hope you can help me to get it for free.
Thank you.
Hi Curtis,
Nice to see you, you can download Free Registry Clean Software by clicking. This is very Simple way to get it. Download it and clean up the registry files of you computer from viruses.
Enjoy.
Hitesh
Hello Curtis Marry,
There are different software's to solve this problem like antivirus but these software also reduce the speed of the system.
For this purpose i recommend to install ADVANCED SYSTEMCARE WITH ANTIVIRUS 2013.
It is the best solution to your system problems and also take the few minutes to fix these problems.
You can easily download this software and read more about this software.
Here is a link:
Regards
If you want a registry cleaner, try PC Tools Performance Toolkit. It is a system optimization tool that also features registry cleaner and registry optimizer to speed up things on your computer. It supports Windows XP, Windows Vista, Windows 7, and Windows 8.x. It requires Intel Pentium 4 or faster processor, 512 MB RAM, and 100 MB free space.
To clean the Windows registry, start PC Tools then go to “Performance” tab and click “Clean Your Registry.” On the next screen, make sure “Complete Registry Scan” is selected then click “Start Scan” to begin scanning the Windows registry. When scan is complete, click “Repair” to fix all problems found.
Once the registry is fixed and cleaned, you need to compact it to optimize application performance and to conserve space. Go back to “Performance” tab and click “Compact Your Registry.” On the next screen, make sure “Create System Restore Point” is checked then click “Start” to start analyzing your system. Click to restart the computer when you are prompted to finish the optimization.
